What ecu to get???
Old May 1, 2002 | 08:32 AM
vtec69's Avatar
Default What ecu to get???
I have a 98 civic dx and i am dropping a ls/vtec with a 2000 itr head and componets, with a 93 ls block.
I have the itr wiring harness but was wondering what ecu to get?
I think my dx is a obd2 but do i get an obd1 so there aren't so many engine codes problems? I am also putting a carsound cat on my car will i need 1 or 2 o2 sensors? Also give an example of an ecu such a a 2000 type-r ecu, 95 gs-r ecu, or what ever ecu would work the best.
Thanks
Old May 1, 2002 | 09:05 AM
kenji's Avatar
25 Year Member
Default Re: What ecu to get??? (vtec69)
I have a good P28 program that will run your LS/VTEC setup very well. You will need an OBD2 to OBD1 ECU conversion harness as well.
Ask some H-Tech members what they think about my ECUs and harnesses.
Email me for more info.
-kenji
Old May 1, 2002 | 10:53 AM
infuryum's Avatar
Default Re:
I can vouch for the quality of his harnesses. Very nice pieces. I've been using one for almost two years now and I love it.
Old May 4, 2002 | 02:34 AM
black92si's Avatar
Default Re: What ecu to get??? (kenji)
hey kenji, i have a b16a in my 92 si. you got anything to help me out? right now i'm running the stock ecu. i need a higher redline and a better fuel map. FYI, the motor is a stock b16a (1st gen) and i got a AEM CAI. thanks in advance!
[Modified by black92si, 11:35 AM 5/4/2002]
Old May 4, 2002 | 08:13 AM
eg6ajk's Avatar
Default Re: What ecu to get??? (black92si)
what ECU are you running?? if its a P28 then you can get it rechipped to many different specs or simply buy a rechipped ecu
FeedBack159
Honda CR-V & Element
Oct 31, 2012 08:28 PM
Red-Rag-B18
Apr 22, 2010 08:12 AM
mawkiemarc
22
Feb 28, 2006 12:21 AM
Big Teggie
Oct 2, 2001 11:19 AM
