B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works?
Old 04-29-2002, 06:03 PM
cursED's Avatar
Default B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works?
I believe flywheel can be from 99-00 Si, 90-91 Integra (but I don't know which engine), or 93-94 del sol VTEC.
Clutch should be for 90-91 Integra only?? How is that? clutchcityonline.com notation for this clutch says 25mm spline - is that correct?? Anyone, and I mean ANYONE used another clutch setup successfully with their swap (B16A1 with Y1)?
Your help is most appreciated.
Thank you all
Old 04-30-2002, 09:14 AM
cursED's Avatar
Default Re: B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works? (milk
ttt
Old 04-30-2002, 01:02 PM
Rocket's Avatar
25mm spline like the 90-91 USDM integras.
99+ SI flywheels only accept 6 bolts for the pressure plate.
90+ Integra Flywheels are 9 bolts.
All pressure plates for the B-series are compatible but 99+ SI's are 6 bolts instead of 9 bolts.
Drop me a line if you have more questions. I know a **** load about clutches.
Old 04-30-2002, 01:03 PM
Rocket's Avatar
Short answer:
Get a set-up that will work for a 90-91 integra and you'll be cooo.
Old 04-30-2002, 05:15 PM
cursED's Avatar
Thank you, Rocket! Guess stock replacement for 90 Integra is out of the question, or is the actual application for the B18B (having more torque?); and therfore, can a stock replacement last in a B16A1 application?
Old 04-30-2002, 10:29 PM
Rocket's Avatar
If you plan to do any type of spirited driving do not use organic. I say this all the time and I'll say it again. Organic linings and sprung hubs are not for racing. Organic lining is like cookie dough compared to other materials available. The springs in the hubs are waiting to pop out. What's better a hammer with a solid handle or a three piece one with springs.
Also if you like to downshift you should get a "Clipless" pressure plate. ACT, Action, and some HondaClutc(Herson) have this design.
Here is a pic of a clip. They tweak on downshifts and rub on the cover and prevent clutch disengagement.
Old 05-01-2002, 09:34 AM
cursED's Avatar
Rocket - you are the man!
Thank you for the detailed info!
Deal on clutches = where??
Deal on JUN flywheel = where??
Old 05-01-2002, 10:10 AM
Rocket's Avatar
Drop me a line and I'll help you out.
Old 05-02-2002, 11:49 PM
dlric's Avatar
i've got a clutchmasters 6-puck unsprung clutch w/pressure plate for b16a cable tranny's
send me an im if interested for pics
fwdlooser93eg
07-24-2006 06:52 PM
PhatBoy5015
03-21-2006 06:08 PM
flip1199
11-07-2005 11:07 AM
integraautox
01-23-2003 01:14 PM
2muchPSI
01-23-2003 09:06 AM
Quick Reply: B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works?
