VAFC apexi?
Old May 1, 2002 | 02:23 AM
infamousALLMTR's Avatar
Default VAFC apexi?
how hard is it to hook up one of these? is there a lot involved in tuning this to perfection? need some info on this before I move forward, thanks.
Old May 1, 2002 | 04:03 AM
tinkerbell's Avatar
Default Re: VAFC apexi? (infamousRRH)
if, hypothetically speaking, your VTEC did not work 'cause you have a VSS code,
can the VAFC over ride this and get VTEC going?
t..
PS is there any other way to trick the ecu that it 'can' go into VTEC?
Old May 1, 2002 | 04:27 AM
VTECVillain's Avatar
They are not hard to wire up if you can follow directions and feel confident doing it. If not, leave it up to someone who has installed one or is good with auto wiring. You will be tapping into sensors and that could be a disaster if you hook up a wrong ground, go to the wrong pinout, etc.
The tuning is probably more involved than the install in my opinion. I wouldn't play around too much with it unless you have it on a dyno and see the results of the changes and whether or not they are working for or against you.
envious_accord
Jun 8, 2006 11:59 PM
willie_d18
Sep 17, 2004 07:04 PM
USDM 4G VTEC
15
Oct 10, 2003 08:19 PM
sicklexus1
May 4, 2003 09:10 AM
Wong Wonder
Feb 8, 2003 04:10 PM
