b series motor on a 90CRX SI??" what kind of mounts?
what kind of motor mounts should be used in order to fit a GSR motor into a 90 crx si? the stock hood is going to be used, we need something that'll clear the hood. any info would be appreciated.
Re: b series motor on a 90CRX SI??" what kind of mounts? (S2Kpower)
FYI... HASport mounts places the motor slightly higher (about an inch) than the HCP mount kit. Therefore, you're going to run into clearance issues with your hood. With the HCP mount kit, it barely hit or rubbed the stock hood on 2 CRXs with B18C motors. One guy cut the underside of his stock hood in a few places and that solved that problem.
I sell the HCP mounts... http://www.JDMshit.com
Get whatever mounts you want to, but I'm just saying some facts that I know and have seen from first hand experience.
Location: A place where stupidity runs rampant aka NorCal
Re: b series motor on a 90CRX SI??" what kind of mounts? (Newman)
HCP has better customer service also, having dealt with both companies (and Im using the ef-18x kit with 0 problems and alot of track time under my belt)
-Todd
-Todd
Trung Nguyen
18
06-15-2010 02:29 PM
jtm509
04-05-2010 09:17 AM
Blazin Si
04-11-2005 05:34 AM
