check code
Old May 1, 2002 | 12:07 PM
hybrid901's Avatar
Default check code
We just finished a 95 b18c1 2.0 swap into my buddys 90 crx si. We are using a 88-91 b16 ecu. He is getting a code 23, we have replaced the knock sensor but the code is still there. Can code 23 be anything else. His vtec also cuts in and out sometimes. Do we need to run a shealded wire for the knock sensor? I've never had to do this on any of the other swaps before. But I guess we will be trying that next.
_______
Old May 1, 2002 | 12:59 PM
holeshot2's Avatar
Default Re: check code (hybrid901)
what pin did u wire up the knock sensor to???also did you solder the wires or just twist them together for testing??
02spoon
Oct 17, 2010 09:48 AM
EF_FEVER
Feb 22, 2007 12:32 PM
R@mon
Jan 7, 2003 02:28 PM
Chris_
Apr 15, 2002 07:01 AM
