need help on a swap
Old Apr 30, 2002 | 12:27 PM
hatchBtype_R's Avatar
Default need help on a swap
can any one help me with a swap with a 95 LS into a 92 hatch VX
Old Apr 30, 2002 | 01:05 PM
JeffS's Avatar
Default Re: need help on a swap (hatchBtype_R)
What do you need? That should be a VERY straitforward swap.
Old Apr 30, 2002 | 02:36 PM
93dx--hatch's Avatar
Default Re: need help on a swap (JeffS)
is the difference in the ls swap and a b16 swap the wiring?
Old Apr 30, 2002 | 03:50 PM
JV's Avatar
JV
Who?
Default Re: need help on a swap (93dx--hatch)
Just plug and play......
Old May 1, 2002 | 10:43 PM
yeah i was wondering how do you wire it up
Old May 2, 2002 | 07:59 AM
PhucNguyen57's Avatar
actually...
Isn't the VX a Vtec efficiency motor? this may not be as strait forward as everyone is claiming. You will not need to ust the wires that go to the vtec selonoid and you may have to make some wires longer or shorter for everything to plug in. If you have minimal mechanical experience you should be able to figure it out.
I have found in my experience that nobody knows what the **** they are talking about and the best bet is just to figure it out yourself.
Old May 2, 2002 | 11:18 AM
JeffS's Avatar
If you have a 95 LS with a 95 LS engine harness on it, and a LS ECU, then you just drop the engine in, plug the 95 LS engine harness into your 92VX chassis harness, plug the 95LS ECU into that and you're good to go.
Hi-Tech Honda Girl
24
Feb 2, 2007 05:17 PM
Boofster
Jan 27, 2004 07:49 PM
CivicTuneR95
Oct 25, 2002 09:36 PM
T.Werd
Jan 23, 2002 07:19 AM
GorData
Nov 27, 2001 09:28 PM
