B16 in a G2 integra?
Old Apr 25, 2002 | 02:26 PM
WhoNeedsBoost's Avatar
Default B16 in a G2 integra?
How hard? it should bolt in right? both B series... only thing is wiring vtec in right?
Old Apr 25, 2002 | 03:03 PM
B20bTurbo's Avatar
Default Re: B16 in a G2 integra? (WhoNeedsBoost)
Yes they bolt right in, it's a very good swap. What year is your teg? If it's 92-93 your better off getting the obd1 b16, if you get the first gen b16a it's obd0 and some things will have to be changed.
Old Apr 26, 2002 | 01:10 PM
EVOCELICA's Avatar
New User
Default Re: B16 in a G2 integra? (B16aTurbo)
not really he can use his ls injectors and just shave an ear off the distrib. all he will need to buy is the ECU
Old Apr 26, 2002 | 06:44 PM
eg6ajk's Avatar
very easy 90-1, cheap and easy, just add four to five wires and be done
vtec pressure, ground, vtec selnoid, knock and second 02
92-3 integra, using second gen b16a is also the same way as above, (requires only four wires )
with right ecu program such as Mugen (90-1) can run only 1 wire connected to the vtec solenoid and run without any problems
Sean5826
Sep 22, 2024 06:15 PM
jdeeezy
Jul 9, 2008 07:29 PM
twizzle
15
Apr 3, 2006 01:41 PM
acuramike
Sep 13, 2005 04:35 AM
LsTurbo91
Jul 28, 2001 09:05 PM
