Normal Compression #'s and Flywheel recommendations?
Old Apr 26, 2002 | 12:43 PM
hybrider's Avatar
Default Normal Compression #'s and Flywheel recommendations?
im about to try and perform a comp test by myself, wonderig what are normal numbers for a GS-R? (keep in mind, `95 w/60-70k miles)
also, i was thinking of going with an exedy clutch and today flywheel? too light? any recommendations from fellow hybriders?
thanks in advance
Old Apr 26, 2002 | 06:21 PM
eg6ajk's Avatar
Default Re: Normal Compression #'s and Flywheel recommendations? (hybrider93)
remeber to have the WOT when testing (remove the ecu fuse when cranking, so no fuel gets pumped)
numbers of 160+ psi and spread of no more then 25psi or so between cylinders, look for consistent numbers of around 180-210psi, and you be more then fine
exdy clutch are good, but when going with the stock replacement clutch from exedy, then you're better off with just ITR setup which is alittle cheaper but very alike to exedy.....toda flywheel is excellent, basically nothing lighter then 8lbs is good for the street..... other choices are CM or Fidanza, Spoon, JUN and few other JDM names
ShinotakuX
Jul 13, 2008 07:24 AM
bseries_beast
Aug 3, 2004 08:08 PM
92SiBlu
Mar 28, 2004 03:46 AM
pub
Aug 11, 2003 06:50 PM
hybrider
May 2, 2002 01:04 AM
