itr swap
Old Aug 6, 2003 | 04:32 PM
clayj's Avatar
Default itr swap
I have a 94 VX and tryin to clear things up on the swap before it gets here. Can I use the itr motor mounts and the thottle cable? And what mount for the AC? Is it hard to wire a 5wire 02 to a 4 o2? thanks in advance
Old Aug 6, 2003 | 04:35 PM
poison's Avatar
Default Re: itr swap (clayj)
You have several options. Is the ITR swap US or JDM?
Yes you may use the ITR motor mounts. For the mounts for the A/C just use the A/C bracket that comes with it.
As for the 5 wire to 4 wire O2, it takes a little time, but is faily simple. But that mainly depends on what swap you use.
Old Aug 6, 2003 | 04:43 PM
clayj's Avatar
Its a us itr. Can I use the throttle cable from the itr in my hatch?
Old Aug 6, 2003 | 04:44 PM
poison's Avatar
Default Re: (clayj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayj &raquo;</TD></TR><TR><TD CLASS="quote">Its a us itr. Can I use the throttle cable from the itr in my hatch?</TD></TR></TABLE>
Yep you can. If it's a US ITR, you can have it 100% plug and play using the ITR harness. What ECU you using?
Old Aug 6, 2003 | 04:52 PM
clayj's Avatar
Im thinkin about goin with a chipped P28 from Kenji. $209ecu and shipping. good deal?
Old Aug 7, 2003 | 01:28 PM
clayj's Avatar
If I use the chipped P28 will I have to change to a 4 wire o2?
Old Aug 7, 2003 | 02:46 PM
poison's Avatar
Default Re: (clayj)
No, if you use the ITR harness, and a P28, the swap will be 100% plug and play.
2mansi
Mar 8, 2008 12:19 PM
knalige
May 27, 2004 06:37 PM
