What mounts do I need to put 96 LS motor in 96 Civic EX?
Re: What mounts do I need to put 96 LS motor in 96 Civic EX? (yellaboi)
specifically I need to know if the integra mounts or civic mounts will work. I know the driver side mount is different but will civic mount bolt to ls engine.
I have not seen any mount kits for this swap so I'm assuming factory parts will work.
Ok listen up. You will need the B series front lower tranny mount and the B series ac mount. Only B series parts work here. You will use the factory civic trans mount but then you will need the metal bracket for the back mount from a 99-00 Civic si. Its a big metal bracket and attaches from the back of the tranny to the back mount. The only other B series mount you need is from a 99-00 civic SI and its the side cast iron bracket that bolts to the side of the block under the timing cover. All the stock civic side mount parts will bolt to this bracket. Good luck.
Re: What mounts do I need to put 96 LS motor in 96 Civic EX? (Trey)
thanks that's exactly what I needed to know. what about axles will the hook up ok to the LS engine?
Also will the civic shift linkage work or do I need to find integra linkage.
Modified by yellaboi at 8:27 PM 8/7/2003
another quick question. the GSR and SI drivers side bracket look almost identical is there really a difference besides the longer studs?
civicmobileone
04-25-2007 12:38 PM
GeekinEK
11-21-2004 10:41 AM
