H22 Engine Bays
Old Aug 6, 2003 | 12:34 PM
DropSquadCivic's Avatar
Default H22 Engine Bays
I was just wondering if some of you guys with h22 in your EGs post some pics of your engine bays, so i can get an idea of where you guys bolted-up your MAP sensor and vaccum lines setup and stuff......
Old Aug 6, 2003 | 02:19 PM
poison's Avatar
Default Re: H22 Engine Bays (DropSquadCivic)
here ya go:
Old pic:
I mounted my MAP sensor on the firewall right next to the resistor box.
HTH.
Old Aug 6, 2003 | 02:29 PM
Default Re: H22 Engine Bays (poison)
cool ****, thanks! Hope fully get my swap done this week!
Old Aug 6, 2003 | 03:52 PM
fastwanabe's Avatar
you can see here how the fuel filter is mounted with the stock fuel line(you need 90 Accord fuel rail to use the stock line)
this is how she looks now
Old Aug 6, 2003 | 04:36 PM
jeff652's Avatar
Old Aug 7, 2003 | 01:23 PM
kwik93si's Avatar
Default Re: H22 Engine Bays (jeff652)
here's some pics of mine
Old Aug 7, 2003 | 02:47 PM
poison's Avatar
Default Re: H22 Engine Bays (kwik93si)
hey bro, what TB is that?
Old Aug 7, 2003 | 03:13 PM
2.2L EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">hey bro, what TB is that?</TD></TR></TABLE>
it looks like an STR TB
Old Aug 7, 2003 | 03:43 PM
kwik93si's Avatar
it's a 70mm STR
Old Aug 7, 2003 | 05:25 PM
Default Re: (kwik93si)
[img]C:\Documents and Settings\Owner\My Documents\My Pictures\h22\2003_0807\h22 075.jpg[/img]
what did you guys do with this?
Old Aug 7, 2003 | 07:09 PM
v4lu3s's Avatar
RTFM
i jsut let my map dangle on a short tube....and how come no one put their injector resistor box in teh stock location on the driver side strut tower?
i put mine there and just pulled the injector wiring off the lude harness and was able to install the resistor pack without cutting a single wire.
Old Aug 11, 2003 | 04:34 PM
Default Re: (v4lu3s)
I wish i would've taken my time to pull all of my wires to the back of the bay so my bay would look clean as hell
Old Aug 11, 2003 | 07:04 PM
UpstateCivic's Avatar
Default Re: (DropSquadCivic)
I now have an AEM intake on it, this is an older pic. I have the Accord fuel rail as well, I just haven't gotten around to putting it on yet.
Old Aug 11, 2003 | 08:09 PM
Jason kiDD's Avatar
Default Re: (UpstateCivic)
Ahh finally some pics of the beast. Looks great you guys. Keep up the good work and get some track and dyno numbers sometime this year!!
Old Aug 12, 2003 | 03:59 PM
fastwanabe's Avatar
Default Re: (Jason kiDD)
hey upstate,, what header is that? DC? does it hang any lower than the stock piece?
Old Aug 12, 2003 | 06:14 PM
Default Re: (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">hey upstate,, what header is that? DC? does it hang any lower than the stock piece?</TD></TR></TABLE>
Nope, that's the stock exhaust manifold. I just left the heat shield off and sprayed it with some high temp paint.
Old Aug 13, 2003 | 05:29 AM
Jason kiDD's Avatar
I see you have a traction bar. What kind is it and what are you comments on it?
Old Aug 13, 2003 | 07:53 AM
nickwilmot's Avatar
Default Re: H22 Engine Bays (fastwanabe)
HEy I see that jeff652 and fastwanabe Kept thier A/c systems. Jow hard was it to keep A/c with a H22 in a 92-95 civic? Also any clearance issues? Need some advice on keeping A/c in a h22 powered 92-95 civic.
Thanks
Old Aug 15, 2003 | 03:38 PM
fastwanabe's Avatar
Default Re: H22 Engine Bays (nickwilmot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickwilmot &raquo;</TD></TR><TR><TD CLASS="quote">HEy I see that jeff652 and fastwanabe Kept thier A/c systems. Jow hard was it to keep A/c with a H22 in a 92-95 civic? Also any clearance issues? Need some advice on keeping A/c in a h22 powered 92-95 civic.
Thanks</TD></TR></TABLE>it is a tight fit even with the HCP kit, but def doable as you can see. I suggest using a 40-41" in belt so that the alternator isnt hitting the condensor, if your able to do the H22 swap then fitting the A/C wont be a problem.
Old Aug 15, 2003 | 09:19 PM
nickwilmot's Avatar
Cool Thanks
Old Aug 24, 2003 | 03:07 AM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">it is a tight fit even with the HCP kit, but def doable as you can see. I suggest using a 40-41" in belt so that the alternator isnt hitting the condensor, if your able to do the H22 swap then fitting the A/C wont be a problem.</TD></TR></TABLE>
are you guys using the prelude compressor? or the civic?
Old Aug 24, 2003 | 09:40 AM
Newman's Avatar
New User
Default Re: H22 Engine Bays (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G &raquo;</TD></TR><TR><TD CLASS="quote">
are you guys using the prelude compressor? or the civic?</TD></TR></TABLE>
With the HCP H22 A/C bracket, you use the 92+ Sanden A/C compressor and it bolts right up. Use either a Goodyear Gatorback belt (4040410) or a Dayco belt (420K4)
Old Aug 24, 2003 | 01:21 PM
db8sirg's Avatar
eg6 w/ h22a
Old Aug 24, 2003 | 04:28 PM
poison's Avatar
dayam! now THAT is wack.
blingin block too
Old Aug 24, 2003 | 04:43 PM
Turbogixxer's Avatar
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">dayam! now THAT is wack.
blingin block too</TD></TR></TABLE>
Yeah, like the RHD.
