help guys obd2 mini me problems
Old Aug 6, 2003 | 03:46 PM
Timmay's Avatar
Default help guys obd2 mini me problems
ok here is what i have
99 hatch
y7 block
Z6 head and i/m with 99 DX t/b
Z6 headgasket/T-belt
greddy intercooled turbo kit
right now timing is at about 14, 170-180 lbs comp. all 4 cyls
here is the problem: car runs like total ***. boost is at 8-9psi right now and its slower than before with the stock DX head and 5 psi. im about to redo my valve lash cause they are ticking pretty good. also running the stock ecu for now till i get the p2p EX ecu wired up,
now i was thinking maybe just casue vtec isnt engaging that that could have something to do with it, but it feels like crap all the way through the rpm range. im pretty sure the timing belt is good, all the marks are lined up, is it possible that it is 1 tooth off? but at 1 tooth off it wouldnt even run would it?
anyone help me , this is my buddies car and its stressing me OUT
Old Aug 6, 2003 | 06:49 PM
Timmay's Avatar
Default Re: help guys obd2 mini me problems (Timmay)
anyone?
Old Aug 6, 2003 | 06:57 PM
Blown90hatcH's Avatar
1 tooth may let you crank it...but it will run horribly. Codes?
Old Aug 6, 2003 | 07:53 PM
Timmay's Avatar
Default Re: help guys obd2 mini me problems (Blown90hatcH)
only code is o2 for no cat,
ok update i have tried 2 different timing belts, y7 and z6 no difference, ive set it at tdc on both cam and crank moved it 1 each way no difference, WTF?? i think we are just gonna put the dx head back on and say hell with it
Old Aug 7, 2003 | 07:22 PM
So you have tried setting it 1 tooth off and no difference? Are you sure that you are running on all 4 cylinders?
Old Aug 7, 2003 | 07:33 PM
Timmay's Avatar
yea i just put the dx head back on, i think what the problem was i didnt have the timing belt on right, i went tdc/tdc and no go, so i moved the cam 1 degree to the Ex. and no go then back to tdc and 1 tooth to the In. still nothing, i think i was a few teeth off
Old Aug 8, 2003 | 05:30 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">i think i was a few teeth off</TD></TR></TABLE>
That's not good!
GitsNshiggles
Apr 16, 2019 03:51 PM
alwaysbroken
Feb 5, 2009 10:12 PM
lsvtec86
Jan 31, 2009 04:30 PM
rewerbcrx
12
Sep 18, 2008 01:34 PM
VtecSyndrome
Sep 1, 2007 11:17 AM
