pr3 ecu...code 41... how to fix?
Old Aug 14, 2003 | 04:57 PM
absolut b18's Avatar
Default pr3 ecu...code 41... how to fix?
i have a 94 civic vx with a 97 b18c-r jdm. i was running a p30 with no problems. now i connected a pr3 and i am getting a code 41 which i think is something woth the o2 sensor. anybody know how to fix it? thanks
Old Aug 14, 2003 | 07:21 PM
Default Re: pr3 ecu...code 41... how to fix? (absolut b18)
anyone?
Old Aug 15, 2003 | 05:08 AM
mattb16a1civic's Avatar
i believe your right about the o2. check for a break in the wire. or a connection problem at either the sensor or at the pin that connects at the ecu
Old Aug 15, 2003 | 05:19 AM
VTECVillain's Avatar
Code 41 is the heater circuit for the O2. Has the car been converted to a 4 wire O2 sensor previously? I would say it has considering you say that the P30 didn't throw that code. I would clear the code and try the P30 ECU again. Are you sure that you are using a PR3 ECU? If so, is there a reason why you are using an OBD0 PR3 ECU? How did you plug it in, a OBD1 to OBD0 jumper hanress?
Old Aug 15, 2003 | 10:20 AM
Default Re: pr3 ecu...code 41... how to fix? (VTECVillain)
ACTUALLY THATS ONE OF THE THINS I AM CONFUSED ABOUT... THE PLUGS ARE FOR AN OBD 1 ECU. THE ECU SAYS PR3 ON IT. IS THERE SUCH THING AS A OBD1 PR3?
Old Aug 15, 2003 | 11:32 AM
Sounds to me like it's an OBD1 circuit board in a PR3 case but who knows. I've never seen a PR3 OBD1, don't think they exist. Take the top cover off and see if it has the PR3 in the barcode on the top of the ECU plugins.
Old Aug 15, 2003 | 03:25 PM
BUBZC1's Avatar
I heard or read that that was the ecu for a usdm b16a3 del sol.
Just a suggestion though. Hey anybody know why I cant use this tranny from a Prelude Sh in my 94 eg cx
Old Aug 15, 2003 | 05:04 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like it's an OBD1 circuit board in a PR3 case but who knows. I've never seen a PR3 OBD1, don't think they exist. Take the top cover off and see if it has the PR3 in the barcode on the top of the ECU plugins.</TD></TR></TABLE>
proof of OBD1 PR3 existy-yonce!
(found on JDM 92-93 XSi/RSi DA integra's)
The ecu look exactly like a US OBD1 LS/PR4 ecu on the outside but has a TEC motherboard+programming on the inside.
Old Aug 15, 2003 | 06:51 PM
Default Re: pr3 ecu...code 41... how to fix? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
(found on JDM 92-93 XSi/RSi DA integra's)</TD></TR></TABLE>
That's interesting to know. I figured they used the P61 ECU like the USDM 92-93 GSR but I guess not. Thanks for the info.
Old Aug 16, 2003 | 09:01 PM
Katman's Avatar
That's interesting to know. I figured they used the P61 ECU like the USDM 92-93 GSR but I guess not. Thanks for the info. </TD></TR></TABLE>
yeah..
they never had B17's (P61 part number code) in Japan, but the OBD1 pr3 is pretty much a B17 ecu rebadged PR3.
Old Aug 23, 2003 | 01:05 PM
Buster T's Avatar
This is a little OT.
Katman, I purchased a car, '89 CRX, with a turbo B18c1 in it.
Anyway, the ECU has a JDMPARTS.com sticker on it. The ECU sticker reads -PR3-000, and it has a distributor than looks just like any 1989 CRX distributor (OBD0 ?).
Is this a OBD0 PR3 ECU?
Old Aug 25, 2003 | 12:07 PM
Katman's Avatar
Default Re: pr3 ecu...code 41... how to fix? (Buster T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buster T &raquo;</TD></TR><TR><TD CLASS="quote">This is a little OT.
Is this a OBD0 PR3 ECU?</TD></TR></TABLE>
I suspect it to be a OBD0 ecu....
but I normally don't apply a JHP decal on ecu's I reprogram, I do put a sticker near the PR3 part number sticker though.
Old Aug 25, 2003 | 07:24 PM
Buster T's Avatar
Probably the former owner just slapped a sticker on it.
Thank you for answering my question, Katman.
Old Aug 26, 2003 | 09:52 AM
Katman's Avatar
sure thing.
Old Aug 26, 2003 | 02:27 PM
EKhothatch's Avatar
I have a P13 and I'm throwing a code 41. Could it be because the wires were spliced, soldered, and then taped, and they could be exposed or touching? Could there be another reason?
ef-hatchcrap
Jul 30, 2009 02:32 PM
civickid03
Jul 13, 2006 01:29 PM
iheartmyej8
May 31, 2006 05:10 AM
integlikewhoa
Mar 12, 2004 05:32 AM
