JDM B20B Swap help!
* B A N N E D *
JDM B20B Swap help!
Sup guys, Im ready to swap in my JDM B20B into my EG.... when i was attaching my wiring harness onto motor i found out that there was 2 missing plugs going to the MAP Sensor and the Thermoswitch.... is there anyway i can grab the plugs and wires from my stock d16z6 wiring harness and add it onto my 99 integra LS wiring harness? if anyone knows please tell me how i can make this happend without purchasing another wiring harness. Thanks
* B A N N E D *
Re: JDM B20B Swap help! (Blaze45)
So when i cut the plugs/wires from my d16z6 harness (thermoswitch and MAP Sensor plugs) where would the best place to tap them into? the chassis harness? and thanks for the help!
Re: JDM B20B Swap help! (ryan819)
What? You dont have MAP plug? I know that you need to add your thermo switch but the MAP should be hangin around somewhere... I thought that you had the wires for the MAP and the thermoswitch, you didnt have plugs tho... What happend to the plugs on the harness that is in the car???
Blaze
Blaze
Well then you must have some wires just hangin around that dont go to anywhere.... Right? The thermoswitch you can use any old 2 prong plug off the D harness. As for the MAP you need the specific one that was a 3 prong plug.
Blaze
Blaze
* B A N N E D *
hmm... ill cut open the wire loom to see if there are cut wires and if there are then ill just solder the D-series 3 prong MAP sensor plug and hte 2 wire thermoswitch to harness unless the 2 wire thermoswitch wire is connected somewhere else.....
zildjianmatt
05-31-2012 11:26 AM
MR.johnson
12
04-27-2008 06:10 PM
BAZ
04-08-2005 05:07 PM
