Triming transmision mount???
Old Aug 9, 2003 | 04:28 AM
Pete_SI's Avatar
Default Triming transmision mount???
Hi,
I want to know why you have to trimme a piece of the transmission mount bracket in a h22 EG. Because if you cut a piece can you still use it again? I'm probably going to do the swap and I just want to know everything I can before doing. ohh and btw I'm talking about the HCP mount kit.
Thanks
Old Aug 9, 2003 | 11:20 AM
Pete_SI's Avatar
Default Re: Triming transmision mount??? (Pete_SI)
bump...
Old Aug 9, 2003 | 11:27 AM
UpstateCivic's Avatar
Because you can't shift w/the piece there. They say you can reuse the mount, but I couldn't. I also had to redrill the hole for the bolt to go through.
Old Aug 9, 2003 | 11:40 AM
Pete_SI's Avatar
Default Re: Triming transmision mount??? (UpstateCivic)
What I can understand you still use the mount braket to put your mount in but you have to redrill hole to put the mount. Am I right or wrong
Old Aug 9, 2003 | 11:53 AM
Correct. You have to redrill the hole for the bolt.
Old Aug 9, 2003 | 11:54 AM
Pete_SI's Avatar
no body knows a good thread about how a H series tranny works.
Modified by Pete_SI at 8:34 PM 8/9/2003
Old Aug 9, 2003 | 03:55 PM
Pete_SI's Avatar
Can somebody tell me a good thread about how a shifter cable works.
hondayute
Nov 13, 2007 08:47 PM
90redintegra
Dec 8, 2006 06:17 AM
gooberwolf
Jul 24, 2006 11:43 AM
