Red A/C Wire?
Old Aug 9, 2003 | 11:58 PM
jl21ah's Avatar
Default Red A/C Wire?
I put my gsr swap in my ek, and I bolted up my A/C using the del sol vtec front lower mount. I connected everything (belts pully's, etc.), but one damn RED wire. I don't know where it should go. I forgot where I pulled the wire out of in the heat of the moment. Anybody know where the hell this wire is supposed to go?
Thanks
Old Aug 10, 2003 | 01:05 PM
jl21ah's Avatar
Default Re: Red A/C Wire?
ttt
nobody knows where the hell this wire goes?
Old Aug 11, 2003 | 09:48 AM
kreush33's Avatar
Default Re: Red A/C Wire? (jl21ah)
i can check for you on my civic but first i got a question for you. I have a 94 civic with a gsr motor. What bracket, belt and tensioner did you use for your swap.in the mean time i'll find out where the red wire goes. does it come out of the compressor? or the wiriing harness for the engine?
Old Aug 11, 2003 | 06:31 PM
jl21ah's Avatar
Default Re: Red A/C Wire? (kreush33)
Yo, thanks for your response...
I acutally found out where the red wire goes...I just didnt look hard enough. It goes just about where the compressor is, on the fan assembly. There is a seperate plug just for the wire, I guess the wire came out while the A/C was getting tossed around while we were pulling the engine. But, I found it already, so thanks.
To answer your question, I used a Del Sol VTEC A/C Bracket. I think it has to be 96-97 but I am not sure. I picked one up from my dismantler friend for 70 bucks. It came with the pully, tensioner, etc... I just re used the dx belt...it fit coooo.
roosie
Mar 11, 2019 09:47 AM
civicorprelude6
Audio / Security / Video
Jun 5, 2010 09:29 PM
0ne-Cam
May 17, 2009 08:16 PM
blackhatchy
Sep 27, 2003 07:43 AM
MonkeyMagic
Jan 29, 2003 06:02 PM
