Misplaced ect sensor wire the cause of my CEL?
Old Aug 6, 2003 | 10:10 AM
Nerv2g's Avatar
Default Misplaced ect sensor wire the cause of my CEL?
Ok I can not go outside and switch the wires because I am away for 3 weeks. I am using a GSR wiring harness for my B18C6 (Euro ITR) swap. For the longest time I could not figure out why I kept getting a CEL 6(ect sensor) but I was looking at some pics and I think I was trying to plug the wrong connector to my ECT sensor. Notice on the pic of my motor that the plug that goes into the sensor is green. I think that it is suppose to be grey!! Well if that's the case it's good and bad. Good because I know what the probelm is but bad because i'm a dumb *** Thanks for the help
Old Aug 7, 2003 | 07:37 AM
Nerv2g's Avatar
Default Re: Misplaced ect sensor wire the cause of my CEL? (Nerv2g)
Well?
Old Aug 7, 2003 | 08:50 AM
CanuckCRX's Avatar
New User
I dont know what the heck is up with the wiring, but dude please lose that valve cover breather...hook up the hose from your intake to the valve cover..please
Old Aug 7, 2003 | 08:53 AM
CanuckCRX's Avatar
New User
What colors do you have in the green plug?? Do you have blue and black??
Your ECT wires should be green/black and red/yellow...do you see those wires?
Check to make sure that you don't have your ECT and VTEC oil pressure switch backwards.
Old Aug 7, 2003 | 09:11 AM
ITRacer121's Avatar
Default Re: Misplaced ect sensor wire the cause of my CEL? (CanuckCRX)
you know you could be right b/c Im not sure the Euro models have the Vtec pressure switch ? I know the JDM models dont . unplugg the green one and plug in the missing one and see if you throw a COde 22 (vtec pressure switch) when you get back into town
Old Aug 7, 2003 | 09:45 AM
Nerv2g's Avatar
Default Re: Misplaced ect sensor wire the cause of my CEL? (ITRacer121)
Thanks for the replies guys you guys are the best Now I just need to see if my motor has a vtec pressure switch. Thanks again
Old Aug 7, 2003 | 10:17 AM
Nerv2g's Avatar
Ok Ii have found out that my car does not have the vtes pressure switch, it is like the jdm version, it is controled by the ECU. Do I need all the parts included in the #9 box? Thanks again
Old Aug 8, 2003 | 10:27 AM
Nerv2g's Avatar
well?
Old Aug 8, 2003 | 12:19 PM
CanuckCRX's Avatar
New User
Did you check the wires at the plug?? Do you see the wires that are supposed to be there??
Yes you need all the parts there, what are you going to do, remove parts from the head??
Look for the two wire colors that you are supposed to have at the ECT and plug them in..
Modified by CanuckCRX at 10:26 PM 8/8/2003
Old Aug 8, 2003 | 12:38 PM
Nerv2g's Avatar
What's ecty?
Old Aug 8, 2003 | 06:27 PM
CanuckCRX's Avatar
New User
I meant ECT - coolant temp sensor
Old Nov 28, 2003 | 05:05 AM
Home Skillet's Avatar
Any resolution to this? I'm having the same problem. Any more ideas?
Old Dec 5, 2003 | 02:21 AM
BlkGSR's Avatar
Default Re: Misplaced ect sensor wire the cause of my CEL? (Home Skillet)
are you positive that the green connector is the ECT?
guessohw
Nov 11, 2011 02:50 PM
masijdm
19
Jun 18, 2009 02:45 PM
byronl
Feb 17, 2007 03:26 PM
BlueShadow
Jul 20, 2005 12:24 PM
UNKNOWN_MEMBER
Jun 27, 2005 02:27 AM
