What CEL's did you have, and how did you fix it?
I am just trying to make a list, so in the future, people can find a fix easily
CEL 22 - vtec something
problem: Vtm wire wasn't hooked up on my vafc...
Fix: hooked up the wire
CEL 23 - Knock sensor
problem: when I would go into high RPMs, my cel would come on, and put me in a crazy limp mode
Fix: The connector fell out... guess I shifted too hard a few times... reconnected it and it was fine.
New User
Re: What CEL's did you have, and how did you fix it? (SIckH22Atch)
Good idea, but the only problem is not everyone does the same quality work, therefore the possible causes for any particular CEL could be endless. Know what I mean??
This may help you out:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead center sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
