B18c swap hesitation
I'm going to explain this to the best of my ability... when my engine is cold it runs like a champ. No hesitation or anything. After a while of driving/warmin the motor up, the motor seems to hesitate frequently when I get on the gas. It will eventually let loose and go... but at first there is ALOT of hesitation. You can feel it holding back... I'll just list the specs of my car, along with mods I did in order to solve the hesiation issue (which obviously didn't work)....
99 Civic EX
96 JDM B18C motor w/ LSD tranny
OBD1 P72 ECU
Replaced:
Fuel pump w/ Walbro 255 pump
Fuel line from filter to rail w/ GSR line.
Brand new altenator and battery... didn't think this would help, but I needed them
And just some more specs in case you are wondering...
I pulled my a/c and power steering(side note)
Replaced spark plugs, rotor and cap.
Also, I replaced the internals of my stock d16y8 distributor with the gsr internals so it would plug righ into my stock harness.
I am running very rich..lot of carbon in the exhaust pipe.
Any ideas?
Thanks!
Matt
Modified by XSlackerX at 9:21 PM 8/11/2003
Modified by XSlackerX at 9:28 PM 8/11/2003
99 Civic EX
OBD1 P72 ECU
Replaced:
Any ideas?
Thanks!
Matt
Re: B18c swap hesitation (XSlackerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSlackerX »</TD></TR><TR><TD CLASS="quote">After a while of driving/warmin the motor up, the motor seems to hesitate frequently when I get on the gas. It will eventually let loose and go... but at first there is ALOT of hesitation. You can feel it holding back</TD></TR></TABLE>
Are you throwing any CEL's? It sound to me like like your O2 sensor isn't working properly.
Check if there is really high pressure in the coolant hoses, It could be a coolant flow obstruction, or maybe air in the system. Bleed your coolant and see if that helps at all.
Mike
Mike
The o2 sensor sounds more realistic than the coolant pressure. I am running very rich and I don't think the coolant would cause that. But having a bad o2 sensor might? I could be wrong though and maybe ur on to something.
civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
djay86
40
06-01-2011 08:23 PM
