H22 EK Questions (Searched)
This is an odd one. 97 EK with JDM H22 using obd2/obd1 adapter. With a P72 ECU the cars runs ok. Its very driveable but down on power same thing with the P28. With a P13, it misses at idle, not bad but its noticeable. Fuel pressure is set @ 38psi. Any suggestions? Thanks
jeff
Re: H22 EK Questions (Bloodline)
how long has it been like this? which distributor are u using? sounds like it just needs some tuning... distributor/ignition problems often cause a missing idle (jumping idle, not steady...)
Hmm, check your spark plugs and let us know the colors, or take detailed pics of the spark plugs.
Are they brown, black or white? Any build up?
And is it at 38 psi at WOT or idle?
I have mine set at 35 PSI at idle and 39 at WOT.
When I was running at 38 PSI at idle and about 42 at idle, it ran very rich, and idled rough sometimes, until I revved it burning some of that gas.
