headlights get bright when i let off gas
dim when i get back on the gas. only does this why vehicle is moving.anyone ?????.grounds are all good and very clean.alt looks brand new and when motor was swapped we used a brand new engine harness.wtf
Re: headlights get bright when i let off gas (skunked)
no, car is 96 hatch,2000 b16,i/h/e.new cap,rotor,plugs,fuel filter,alt belt.new engine harness and i soldered all connections. used all oem honda parts to.could the alt belt be to tight???
Re: headlights get bright when i let off gas (GRAVEDIGGER)
I don't think it has anything to do with the belt being to tite...maybe too loose but in that case you would hear it. Check the voltage output on the alternator.
Re: headlights get bright when i let off gas (Atuned2.2ccord)
noticed it happens when using the clutch and gas. not brakes . does not do it when the motor is cold.it kind of feels like the car is surging forward to.
vlc92189
10
09-24-2007 08:20 PM
00civicsimobstyle
07-14-2005 04:26 PM
GRAVEDIGGER
22
10-11-2003 11:15 PM
