ok i got the 88 crx hf with a b16 swap running BUT........
like it drives fine, idles anywhere between 900-1200rpm. and no matter if the engine is cold or hot it will stall once i get off the gas even when i am on the freeway or at a complete stop.
if i sit at a light for long enough it will idle for like 15 seconds and then just stall and it trys to stay on like putter and then it just dies.
its like those old cars you see that when you turn the car off and the thing still stays on for about 10 seconds, thats what it sounds like it doesn't want to turn off but it just does.
the car has a type R intake mani.......DC header........aem sthort ram intake......carsound cat and 2(1/4)" exhaust.......and an unorthodox crank pulley...........
we replaced the fuel sensor relay because the car just wasn't staying on at all it would shut off after like 5 minutes and not want to turn back on till i let it sit for like 10 minutes, but we replaced that and it stays on but it still stalls occasionally.
so what can i do? i checked all vacum lines and everything, nothing is unplugged.......the ecu is throwing no codes.....
we think it might be the fuel filter, but we are just trying to get through a full tank of gas before we fix anytthing else to clean out the fuel lines because the car did sit for about 4 months with no motor.
any thoughts on what to do?
and we thought about checking the injectors. thinking that maybe one is going bad.
jonessw20
06-06-2010 04:46 PM
