LIMP MODE ON EK-22?
LIMP MODE ON EK-22?
I just got my LSD put in today(Quaife)..and one the shop forgot to put on a new differential ring gear so my speedometer doesn't work..and two...i have a cut off at 6500?? Also..my clutch pedal is really soft...not stiff like before...help anyone...all i'm really concerned about rite now is the cutoff..???? HELP?!
Re: LIMP MODE ON EK-22? (2trix)
take it bak to the shop. have them fix it. then bitch them out and demand some kind of refund (after they have fixed it) for the hassle.
might seem harsh... but hey.. thats ur car. and (i'm buzzing now)
hehehe
hehehe
Re: LIMP MODE ON EK-22? (teameracer3)
would "limp-mode" still be the culprit of my problem(6500RPM fuel cut off) if i have vtec? Because I thought that limp mode would disable vtec and many other things...? But I'm really hoping that the ring gear is the part causing the problem, because at least then I'll know what the problem is...
um you need to take it back to the shop. you have more than 1 problem that THEY need to fix because they fucked it up
your vtec dosent work because your spedo dosent work, you are in limp mode for an entirley diffrent reason.
Re: LIMP MODE ON EK-22? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">um you need to take it back to the shop. you have more than 1 problem that THEY need to fix because they fucked it up
your vtec dosent work because your spedo dosent work, you are in limp mode for an entirley diffrent reason.</TD></TR></TABLE>
my vtec does still work...that's why i was wondering if that's still limp mode or something entirely different causing my 6500RPM fuel cutoff
iplayloudly
Honda Civic (2001 - 2005)
11-18-2014 03:39 PM
