h22 hatch wont go in reverse???help!!
i have a h22 in my 92 cx hatch. it wont go in reverse at all, in will go in 5th though. even when u move the shift linkage on top of the tranny in wont go??? is it the reverse gear, or maybe just the reverse spring??? i need help. thanks
Re: h22 hatch wont go in reverse???help!! (h22dx)
https://honda-tech.com/zerothread?id=607938
I hope that thread helps. This thing happens alot with h series trannies. It even happened to me. They are pretty weak from what I have heard. One bang of the gears into third or fifth can totally mess up your transmission.
Re: h22 hatch wont go in reverse???help!! (laugHin22CX)
Ok, this is gonna sound totally strange, and you may not believe me, but I SWEAR this happened to me too-- I had the same problem. I couldn't use reverse for a little over 2 months in my swap-- I ordered the synchro set, etc. but it wasnt in yet. I drained the fluid and added GM Synchromesh fluid from the local GM dealer, thinking this may aid the problem until I get my gear in. Anyway, after about 2 weeks of having that fluid in, I was showing a co-worker how my car just won't go into reverse and.. well.. it went into reverse. I did it again.. and again, etc. It now goes into reverse readily, 5th gear grind is gone, and it's been 3 months since that without a problem since! I know, it doesn't sound right, but KENLUDE97 and SIDan from this board will verify-- it's true. Could just be a fluke.
Give it a try, it may save some time and $$$$$....
Re: h22 hatch wont go in reverse???help!! (EK22Tim)
same thing happened to me, reverse died on me for acouple weeks then magically came back, i just try to baby it going into 3rd and 5th now and no problems so far
