Check Engine Light when I coast or slow down
Old Sep 28, 2003 | 06:19 PM
ChrisDaun's Avatar
Default Check Engine Light when I coast or slow down
I'm getting a check engine light come on when I coast or slow down in gear.
'92 Hatch with a '95 GSR swap and skink2 intake manifold. Also got a whistling sound when I gas it. Think that might be because of my small *** LS throttle body? Anyway, its throwing Primary O2 sensor code. Any help would be sweet.
Thanks in advance
Old Sep 28, 2003 | 08:17 PM
aLLjDMRalf's Avatar
Default Re: Check Engine Light when I coast or slow down (ChrisDaun)
my crx used to do that but it was cause i was using an auto ecu, but i dont think thats ur case best bet is to swap out the o2 it's not to hard and thats more then likely causing ur prob. good luck and let me know how it goes
-Ralf
Old Sep 29, 2003 | 02:56 PM
Milf Hunter's Avatar
My friend has a turbo H23 and his was doing the same thing but all he needed was a map sensor bypass valve.
My intake man. makes that same whistling sound.
Old Sep 29, 2003 | 04:18 PM
ChrisDaun's Avatar
Default Re: (Milf Hunter)
so you think it could be the map sensor?
Old Sep 29, 2003 | 04:27 PM
yeah, aftermarket manifold could be tripping the sensor....my 2 cents
Old Sep 29, 2003 | 04:29 PM
so the whistling sound is from the smaller throttle body?
Old Sep 29, 2003 | 06:25 PM
cavakilla's Avatar
should replace o2 sensor... the sensor is showing lean when you close the throttle body... if you know the sensor is bad you must fix it before diagnosing anything else... the whistle is coming from your intake...
omaralbasri1
12
Mar 11, 2012 08:28 PM
ryanangelo212
Oct 30, 2010 10:19 AM
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
Kent in KC
Jan 7, 2008 01:08 PM
JDMF22B
Oct 11, 2004 07:04 AM
