OBD 2 - OBD 1
OBD 2 - OBD 1
I've searched and I still have one question. I have a 97 civic. I got a 2001 H22 which is OBD 2B and wiring harness with it. I am using the OBD 2B wiring harness so do I need an OBD 2B - 1 jumper or OBD 2A jumper?
Re: OBD 2 - OBD 1 (uncle)
You need the jumper from whatever your car is, to whatever ecu you are running.
it would be obd 2- obd 2b if you are runnin the h22 2001 ecu.
http://www.locashracing.com makes those PERFECTLY.. Nicest unit out there... Tell him Del sent you.
guyuenvy
05-16-2002 12:27 AM
