b18c-r
Car: 1992 cx
Motor: 1996 B18C-R jpec
I have seen many topics about this swap and also a how to made by tom but i need to know about the vtec pressure switch.
On my vtec assembly i see where the switch should go but its plugged up. Can i install the switch there? Or do i need the whole Assembly?
I had the same issue... it seems that the JDM vtec solenoids have a plug there in stead of the sensor.
I took care of the problem by putting my old vtec solenoid on in place of the JDM one (I originally had a d16z6). I think that if you use the JDM ecu, then you don't need that switch... but anyone who knows more feel free to correct me if I'm wrong.
I thought 14 was the vtec solenoid. But that has nothing to do to where the pressure switch goes...So i am stumpd on what i need to buy.
Can someone with the knowlage tell em what numbers i need from the pic?
Thanks need to get this motor running!
I think you need #9 (the whole assembly) unless you can unplug the "plugged" hole where the vtec press. switch goes....
If you can, then just buy the vtec press. switch & be done with it..(#15)
Apexi-ITR knows the exact answer because he did the exact same swap in his hatchback.
There was a very old topic about this, so it will be hard to search because I don't know who started it.
I *think* Apexi-ITR/Hurrell posted in one of my old topics concerning the VTEC pressure switch, so let me find it.
I think he simply took the VTEC pressure switch from his old D16Z6 and bolted it up somehow, but let me double check.
i had the same problem. i wired the vtec pressure in with the vtec solenoid wire and solved the problem. but now, i have to make sure my motor is warmed up and has ample oil pressure before i take the revs to vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard »</TD></TR><TR><TD CLASS="quote">i had the same problem. i wired the vtec pressure in with the vtec solenoid wire and solved the problem. but now, i have to make sure my motor is warmed up and has ample oil pressure before i take the revs to vtec</TD></TR></TABLE>
Thanks but i rather the pressure switch determine if i have the oil pressure for vtec not me.
From: Toronto, Canada currently residing in ATL, GA, USA
Tom is correct. You need the whole pressure switch assembly off of a USDM vtec car. I got mine off a GSR. I would imagine a SOHC D16 vtec motor would work as well.
This is of course if you are running a USDM ECU.
Swap the solenoids out and you should be good to go.
