H22 into a Ek wiring questions
i have a LX automatic, goin for the manual swap when the motor is purchased. do i use the existing wiring harness and wire in, or do i use the H22's harness. if i have to wire in what wires do i have to attend to. also will the auto to manual on a h22 into a ek be difficult.
I use the Stock EK Harness and modify it to fit the H22A motor. If your H22 has an OBD-1 ECU, just use a conversion harness like Skunk 2s or a few others to make the ECU plug in. Then its as easy as adding your VTEC, Knock, and VTEC pressure switch. If you use the OBD-1 ECU you will also have to wire in a Resistor box which isnt that hard to do.
mikegeezy
03-13-2006 08:18 AM
