shopping list check
im am going to assume you are putting an integra motor in the 95 civic Cx from your sig...
no, you wouldn't need an integra suspension to run that motor. an aftermarket suspension would be beneficial, but it isn't necessary.
Re: shopping list check (Sleeper95CivicCX)
Motor
Tranny
Mounts
ECU
Axles
Shift linkage
Throttle cable
Also, be prepared to run to the local Honda/Acura dealership for miscellaneous odds and ends that you may need.
Good luck bro.
Tranny
Mounts
ECU
Axles
Shift linkage
Throttle cable
Good luck bro.
noboostedEGo
10-20-2005 12:39 PM
ysrhatch
03-18-2002 08:19 PM
