H22 Balance Shaft Belt Installation Question
When installing the balance shaft belt, I see how to line up the front balance shaft pulley... and I know the crank should be at TDC... but the rear balance shaft pulley is confusing me. I can open up the "maintenance hole" and stick something in there, but it moves a little either way cause i dont have anything the exact size to put in there. I would think that there would be some alignment marks... and I see an alignment mark on the pulley but it doesnt point to anything when I have something put in the maintenance hole.
wtf?
thanks
-Charles
Modified by mister2racer at 12:58 AM 9/26/2003
wtf?
thanks
-Charles
Re: H22 Balance Shaft Belt Installation Question (mister2racer)
Re: H22 Balance Shaft Belt Installation Question (laugHin22CX)
balancer belt install instructions: open bag, take belt out, place belt in trash can. done
you dont need that junk, throw it away. balancers are there for fat americans who dont want the car to shake at idle.
One tooth off will vibrate badly. No belt at all will add lil HP and slight if any notice able vibration at idle.
I like JDogg instructions!!! im going to remove mine since my EK is down for the moment.I was thinking of ordering the balnce shaft eliminator kit do yall think its worth the money on getting the kitt?
backinblue92
02-27-2015 09:57 AM
