will a p13 OBD1 ECU run my GSR swapped 93 dx coupe??
like the topic says, i have a hondata s200 p13 that came out of my 93 lude VTEC,(non 4wheel steering) i am doing a gsr swap into my 93 dx coupe, i know i have to run the appropiete wires to the ECU for VTEC to work, thats not a problem, i am using the skunk2 mani,, so no SECONDARIES,, yay! haha
Will this ECU work? i think it should, OBD1 is OBD1,, but i may be wrong and was seeing if anyone had insight on this. thanks
-jimbo yO-!
-jimbo yO-!
Re: will a p13 OBD1 ECU run my GSR swapped 93 dx coupe?? (SofaKing)
Yes, it will work, however you will throw the EGR Code 12 CEL, but that won't affect the performance of the motor...
You`ll also run a little bit rich on the motor as well, due to the mappings are richer for the 2.2 rather than the 1.8.
Re: will a p13 OBD1 ECU run my GSR swapped 93 dx coupe?? (poison)
I think you have to change some pins A15/A16 or something, rings a bell.
I think it's the fuel pump circuit or something.
-PHiZ
-PHiZ
chikichimo
17
07-23-2011 02:47 AM
TEAM JDM-P
04-05-2009 08:20 PM
r.2
11-19-2003 10:37 AM
