engine swap for a 89-91 prelude
hey sup tech buds i have a question anyone knows what swap would fit in a 89-91 prelude i know it sounds hard, but my friend wants to keep his car and swap the original motor. Let me know thanks
Re: engine swap for a 89-91 prelude (hatchBtype_R)
Pretty much any swap you do will require a lot of wiring and custom fabrication to mount it. I've seen an H22, B16, LSVTEC and other swaps in them. There are a few people on this board that have done them. Search around and you should be able to dig up something.
Re: engine swap for a 89-91 prelude (VTECVillain)
The most info you'll find is on the h22 swap.
PlaceRacing makes a mount kit (although I wouldn't suggest using it), as well as the wiring harness, axles, and other miscellaneous brackets you'll need.
