ITR B18C6 into EG hatch...
OK some of you may remmember me posting about wiring questions. I have the engine in now and have a couple of problems. Having problem with rear engine mount. My stock civic mount bracket wont fit, will the B18C1 or C4 mount fit? or the B16A2?
And then there is the wire problem, the plug at the back of the throttle body (see pic below). It has two wires and comes from the engine loom, what the hell is it and where does it connect to, as do not have a matching plug on my civic loom. Much help appreciated, thanx.
Re: ITR B18C6 into EG hatch... (Redsun)
that black cylinder thing on the back of the intake manifold is your IACV. It keeps the RPM's higher when the car is warming up and then as you get to normal temp, it disables and the car will idle around 750 RPM. should be 1 12V wire and depending on what ECU your running, the other wire needs to get run to the correct location.
Your civic harness will have the wires for this, but it may be a different plug style. Simply put the integra plug on your civic harness.
Re: ITR B18C6 into EG hatch... (Slurp56)
Should plug in under the IAC if im not mistaken.
......yea i was trying to save weight so i took out my radiator too. Just took up space lol
Ok thats a bad picture, cos it looks like the wire is coming from that black cylinder, but its not. Its coming from underneath it and runs out from the engine harness.
I havent done anything to the wiring yet. What wires will i need to add for this swap?
I had a look at a ITR and this wire connects to some black thing on the firewall, along with a breather pipe from the intake manifold. Then it runs a pipe to the purge cylinder. Is this what you meant by IACV, Slurp??
You said my civic will have the wires but can't find 'em. How do i put the integra plug on the civic harness. Please guys give me details. Cos i really am dumb with wiring.
ezza
09-16-2005 12:07 PM
