b16a+ctr head...
Old Jun 3, 2003 | 05:06 PM
PotatoePAPA's Avatar
Default b16a+ctr head...
Does placing a CTR head (stock internals) onto a b16a (stock internals)bottom serve a purpose? If so, what significances?
Old Jun 3, 2003 | 05:13 PM
poison's Avatar
Default Re: b16a+ctr head... (SleepyDX)
Higher flowing head with bad *** cams = more power.
'nuff said.
Old Jun 3, 2003 | 05:15 PM
Default Re: b16a+ctr head... (poison)
you mean the ctr head has bad *** cams, or with the purchase of bad *** cams?
Old Jun 3, 2003 | 05:19 PM
poison's Avatar
CTR has bad *** cams from factory.
Old Jun 3, 2003 | 05:20 PM
Newman's Avatar
New User
Both are PR3 heads... the CTR and ITR heads are the same, with same valves, valve springs, retainers, rocker arms, LMAs, etc. Only the cams are slightly different but otherwise they're the same head - they also use a better intake manifold but I'm not counting that as part of the head. All (CTR, ITR, B17, B16) heads are all PR3 castings. Your compression will not change, unless you mill the head, but you'll have better flow and more power in VTEC on your B16.
Old Jun 3, 2003 | 05:26 PM
Default Re: b16a+ctr head... (Newman)
excellent. thank you Newman.
honda_12V
Sep 16, 2012 11:04 PM
joe.wong321
Mar 25, 2008 09:58 AM
integrax97
May 11, 2007 10:24 PM
_gurusan_
Aug 10, 2005 11:46 AM
Sideshow9090
Jun 18, 2002 07:58 PM
