vid of 13.4 pass
vid of 13.4 pass
this one was at 99.9 mph.. cameraman didnt get the 100mph pass
http://teamkorn.tv/akms/racerx.wmv
here one of 13.5 against an RSX on CRACK http://teamkorn.tv/akms/modulo.wmv
Re: vid of 13.4 pass (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Listen to Jason! Post that in the EG forum! </TD></TR></TABLE>
I third that
I third that
Re: vid of 13.4 pass (turbogixxer)
ohhh...... you HAVE to post that **** in the EG forums.... that's an order private.
BTW how the **** did you do that, I trap @100mph also yet I cant get those times.
Re: vid of 13.4 pass (fastwanabe)
some say i can drive the **** out of a honda..
my mods are intake clutch and flywheel magnecore wires chipped p13 open stock header lsd and bfg drag rads that probably only have about a dozen runs left in them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">what program on the P13? does it get rid of the EGR?</TD></TR></TABLE>
I hear that. What'd u do about EGR and all that?
I think that is the difference between your times Fastwannabe. LSD makes a whole lot of difference when you driving down the stretch..
Re: vid of 13.4 pass (redlineh22a)
What happened to 13.1?????
I could have pushed my ITR faster then that!
j/k
Looks like little brother might have a car to compete with big brothers..................
IF I ONLY REV TO 5500!
Good run, grow a pair and get some slicks!
j/k
Re: vid of 13.4 pass (Jason kiDD)
im runnin a ks rom chip... and so far my egr code does not show.. but every now and then it will throw code 42 i think thats what it is...
Re: vid of 13.4 pass (Alaskan98ITR406)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alaskan98ITR406 »</TD></TR><TR><TD CLASS="quote">What happened to 13.1?????
j/k
Good run, grow a pair and get some slicks!</TD></TR></TABLE>
ohh. JP it's on!
NorthernXposure get some slickies and hit that 12 seconds!
j/k
ohh. JP it's on!
Re: vid of 13.4 pass (hot_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH »</TD></TR><TR><TD CLASS="quote">Poison, when are you gonna run? 2060lbs How much did Toms car weigh?</TD></TR></TABLE>
Yep, on a full tank of gas and my damn EX steelies. I need to weigh it with empty tank and lighter wheels.
I'm waiting for my new DSS axle to come in from Frank at DSS as well.
The inner CV joint I've been rolling on and constantly filling up the transmission with MTF keeps leaking due to the inner CV shaft being 2 1/8" when it was suppose to be 2 1/4" -- that's the reason I was not able to 'click' and lock the axle in at all.
Rocky Mountain Raceway has another event on June 20th. Hopefully I can jump on the M/T 20x8x14's again.
Rocky Mountain Raceway has another event on June 20th. Hopefully I can jump on the M/T 20x8x14's again.</TD></TR></TABLE>
Good Luck, You should hit 13s ( i think low to mid) with no problem!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Good Luck, You should hit 13s ( i think low to mid) with no problem!</TD></TR></TABLE>
thanks man
At sea level it should be those times. I just wish I was at sea level. I'm in the friggin sky at 4600 ft.
thanks man
