need help h22 swap
Old Jun 7, 2003 | 03:33 PM
civichbsmn's Avatar
Default need help h22 swap
p5p what ecu is this? is it a obd2 ecu. if so should i just which my harness to a obd2 or just search for a p13 ecu? another reason is i have a gsr dash as well that i just put in to my eg and i rather not cut the clips for the cluster and other thing ect............ but just which the harness (no splicing)
ps - anyone selling a p13 ecu or know where to look also looking to buy some motor mounts thnks
Old Jun 7, 2003 | 03:46 PM
junglerunna's Avatar
Default Re: need help h22 swap (civichbsmn)
Your question is very unclear and hard to understand. Is your motor obd1 or 2?
Old Jun 7, 2003 | 04:02 PM
civichbsmn's Avatar
Default Re: need help h22 swap (junglerunna02)
sorry the motor is a 97 odb2 sorry again also are accord injector the same as perlude beacuse my motoe did not come with any
Old Jun 7, 2003 | 04:17 PM
accordhybrid's Avatar
If you got a 97 prelude engine the injectors that come with that motor are 290cc saturated injectors. What kind of car are you putting the H22 in? I assume a civic if so what you need to do depending on what ecu you are going to run, if you are going to run an OBD I prelude ecu then you need to wire in an injector resistor box and get some 92-96 prelude peak and hold injectors cause that is what the P13 uses and also those injectors are 345cc. If you are going to use any typed of chipped ecu then I believe that you will need to use then some saturated injectors but I don't know for sure.
import_tuner13
Nov 12, 2011 01:03 AM
CD5Accord_Corey
Jul 6, 2011 04:02 PM
Tip14
Dec 14, 2008 10:14 AM
sewelh2
Oct 17, 2006 08:01 PM
skinnyboy
Oct 8, 2005 09:52 PM
