green plug, back of block, what is it, wheres it go?
its a b17, the green plug in the back of the block by the alternator, under the knock sensor, its a 2 wire plug, one wires black, the others white with a green stripe, thats the name of this sensor, whats it do? where do the wires go?(pin outs if available) thanks
Re: green plug, back of block, what is it, wheres it go? (SikCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic »</TD></TR><TR><TD CLASS="quote">i thought it was water temp sensor</TD></TR></TABLE>
you're right, secondary water temp. switch...
Re: green plug, back of block, what is it, wheres it go? (VTECNLUDE)
Did you figure this out for sure? I have the same plug on the back of my b18a block, but there is no wire going to it, however I am not throwing a code.
Re: green plug, back of block, what is it, wheres it go? (spankjelly)
I'm pretty damn sure that that is the knock sensor and the one below it is your coolant temp sensor. The coolant temp sensor has a rubber boot over a small coupler, the knock sensor is green. Thats how it is on my 1g B16
Re: green plug, back of block, what is it, wheres it go? (ad_rock82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ad_rock82 »</TD></TR><TR><TD CLASS="quote">I'm pretty damn sure that that is the knock sensor and the one below it is your coolant temp sensor. The coolant temp sensor has a rubber boot over a small coupler, the knock sensor is green. Thats how it is on my 1g B16</TD></TR></TABLE> your right
that's your ENGINE OIL TEMPERATURE SWITCH this is connects to your radiator fan control module. this is only found on US integra models 90-93. is part of the a/c system.
Re: green plug, back of block, what is it, wheres it go? (Qfactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor »</TD></TR><TR><TD CLASS="quote">that's your ENGINE OIL TEMPERATURE SWITCH this is connects to your radiator fan control module. this is only found on US integra models 90-93. is part of the a/c system.</TD></TR></TABLE>
So....I have a 90-93 block in my crx w/ no air conditioner....should I have this hooked up?
4gencivicef9
07-27-2006 08:31 AM
