del sol A/C bracket mystery partially solved!
1 Post
Ok,
Just got back from the honda dealer. Here's the deal on the del sol
VTEC a/c bracket. P/N p54 is for '94 - '95VTEC ONLY!!
List price is $170.00. The p30 is for del sol VTEC '95-'97ONLY!!
Didn't get price for p30.
Now if I could only find someone to tell me which one is for a '90 CRX sanden comp. on a B17, I could move on to the next annoying litlle problem.
Hope this helps someone with del sol a/c bracket Q's
Re: del sol A/C bracket mystery partially solved! (4crx4me)
EF sanden compressor will not bolt up the Delsol bracket, you can use the pr3 bracket but only 2 holes line up. Be creative or get the hasport adapter.HTH
the delsol bracket is only applicable for putting a bi6 w/ A/C in a EG.
1 Post
Re: del sol A/C bracket mystery partially solved! (fastwanabe)
Is the bracket that came with the B17 the pr3? I'll check it, now.
Fastwanabe, Where in Morris Co. do you live?
I live a couple of blocks from Southern Blvd. in New Prov.
Thanks for answering my Q.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">Is the bracket that came with the B17 the pr3? I'll check it, now.
If the B17 bracket says pr3 on it then its good.
I live in a town called Dover, is NP in Morris county?
Want me to add a twist to your mystery? I got a p54 bracket off my B20.... I'm going to see if it will fit up with my AC.....
Blaze
Blaze
Re: del sol A/C bracket mystery partially solved! (Blaze45)
so the p54 will fit a 00 gsr motor in my 93 civic coupe with my stock compressor correct?
Re: del sol A/C bracket mystery partially solved! (turbocivic4)
P54 AC bracket is needed for 92+ Civic w/B-series swaps. For the EF, you can use any PR3 AC bracket and it'll bolt to the B16 or B17 blocks (same thing) or use the PR4 LS bracket for the LS block, but you'll need to have the AC lines refitted from your EF to the B-series compressor. Otherwise, we also sell an AC bracket made by HCP that allows you to use the Sanden AC compressor and EF AC lines, and allows you to bolt it right up to the car (the Mitshito compressor will not bolt up to the HCP bracket). Check out the pict below for how it looks in the CRX.
Not the best pict since the car was smashed in the front and core support pushed in before I took that pict (which is why the AC lines are smashed into the condensor), but it kind of gives you an idea of how it sits in there.
roc
02-29-2004 06:01 AM
