Help B18 swap into 89 crx si
Old 06-01-2003, 09:45 PM
bottledcrx's Avatar
Default Help B18 swap into 89 crx si
Ok, i'm trading my turbo'd zc crx for another 89 si with no rust or was ever wrecked and 3,000.. So that means im dropping in a b18 non-vtec and and a nice size turbo. I am new to the whole b series swaps and was wondering if i can use a motor from a 90-93 teg or if i have to buy one that was imported from japan(did a search by the way) I know i will need mounts, axles and a shift linkage.. Anything else i'm missing?? Also do you guys think i'll be happy with it compared to a turbo zc..??Just want to make sure i have everything, So the cars not sitting for months !!
Thanks
Old 06-01-2003, 10:41 PM
Cory man's Avatar
Default Re: Help B18 swap into 89 crx si (bottledcrx)
Wiring plugs right in. You can use any 90-91 teg B18a, easier than an obd1 motor. But the only downside is more mileage on an older motor. Id pick the turbo b18 over the turbo zc anyday. HTH
Old 06-02-2003, 05:15 AM
VTECVillain's Avatar
You could use a 90-93 B18A1 or even a 94-01 B18B1 and USDM/JDM doesn't matter. Using the B18B1 isn't anymore difficult other than the fact that you would want to use OBD0 (90-91 Integra) distributor, injectors and ECU to keep it simple. You would also need a cable B series tranny. A lot of people get the 90-91 LS because you can pick them up as a full swap but remember the age and normal condition these are in. If you aren't going to rebuild from the start then don't expect it will have tons of life, especically with boost.
I have a 91 CRX DX with a 96 B18B1 which the motor had only 3,747 miles when I bought it. I'm using a 91 Integra PR4 ECU and distributor and 90 CRX Si injectors and resistor box. I was fortunate enough to come across a 92 YS1 GSR cable tranny which I like much better than the LS because of the shorter gears. I went with the HASport billet mount kit, HASport shift linkage and 93 LS intermediate shaft and axels.
Old 06-02-2003, 08:05 AM
bottledcrx's Avatar
Default Re: Help B18 swap into 89 crx si (VTECVillain)
Thanks alot guys, I know the swap isn't hard i was just unsure what b18 to use. I'm gonna rebuild it and use eagle rods and wiseco pistons with a mild p&p head and head studs and hope that hold 15 psi... Guess we'll see Thanks again
Old 04-27-2005, 10:45 PM
HuffRacer's Avatar
im puttin a B18 into a 90 crx, will it bolt up or do i need diff. motor mounts.
Old 05-03-2005, 06:45 PM
Ajvh2000's Avatar
Default Re: Help B18 swap into 89 crx si (HuffRacer)
You will need different motor mounts, they sell them on hasport.com
Old 05-03-2005, 06:48 PM
Ajvh2000's Avatar
Default Re: Help B18 swap into 89 crx si (Ajvh2000)
Hey i have a b18a1 in my 1989 hf. Do i have to change the wiring at all. Like do any of the pins need to be rearanged. I have everything on and i don't get any fire from it. Any hints....
B-Kerr
10
06-06-2005 11:03 AM
CRseXy
03-04-2005 10:53 AM
Toda Party
04-22-2002 01:24 PM
srollo
32
04-06-2002 10:55 AM
RICEBURNER1406
06-21-2001 07:12 PM
Quick Reply: Help B18 swap into 89 crx si
