sohc vtec ??????????'s
Old Jun 1, 2003 | 09:25 PM
blazin250r's Avatar
Default sohc vtec ??????????'s
what would be the best ecu, injectors, fuel regulator and psi to run in my 89 hatch with the sohc vtec? it has a full exhaust and soon c/a/i. any help would be greatly appreciated as it is runnin slow with the stock si parts. any ideas on what im lookin at as far as what my 1/4 mile time should be? thanks
mike
Old Jun 1, 2003 | 09:52 PM
one slow d16's Avatar
Default Re: sohc vtec ??????????'s (blazin250r)
you have the z6 or y8? which ecu are you running currently?
Old Jun 1, 2003 | 10:34 PM
blazin250r's Avatar
whats the difference and how do i tell. im currently running the stock si ecu
Old Jun 1, 2003 | 10:39 PM
Default Re: (blazin250r)
running the stock crx ecu your not getting...
vtec unless you have a manual or rpm activated switch
7200 redline
fuel curve of the ecu is probably not working well with the car either
what distributor are you running?
Old Jun 1, 2003 | 10:45 PM
blazin250r's Avatar
i have vtec rigged to a shift light to activate till a i get an rpm swich.on the dibstributer i dont know. it has to top mounting ear cut to be able to fit the bolt and adjust it if that helps.
im just gettin into honda's (traded my mustang for it) so im tryin to figure this out.
Old Jun 1, 2003 | 10:47 PM
ok..get a p28 ecu, a wiring harness from "blownhatch" and a 92-95 1.6 distributor.
Old Jun 1, 2003 | 10:53 PM
blazin250r's Avatar
what about fuel injectors and the pressure regulator? they are the stock si components.
Old Jun 1, 2003 | 10:54 PM
blazin250r's Avatar
and what is the diff. between z6 and y8?
Old Jun 1, 2003 | 10:55 PM
replace them with the parts from the actual motor in the car.
Old Jun 1, 2003 | 10:58 PM
z6 - 92-95 1.6sohc vtec(civic ex or si) y8 is the 96 on 1.6sohc vtec. if you look on the block on the passenger side just below the head you should see the engine code..d16zk or d16y8
Old Jun 2, 2003 | 12:12 AM
xSpooNxEkx's Avatar
go use a p28 ecu and buy a jumper
Old Jun 11, 2003 | 10:48 AM
blazin250r's Avatar
happen to be any cheap p28 ecu's hangin around anywhere? maybe a distributor?
axis11
Dec 17, 2019 02:17 AM
scooterbuilteh2
Oct 27, 2009 11:44 PM
HatchMo
Jun 24, 2005 08:52 PM
krazeemidget
May 9, 2003 12:37 PM
foesicks
Dec 26, 2002 09:00 AM
