H22 guys..... Speedo is almost accurate if.....
I just swapped out my 205/40/16's out for a set of Azenis 215/45/16 and my speedo is only 3-5 mph off @100mph. I went to the track and I was trapping 98-100mph and my speedo would read between 100-105mph when I trapped @ 100. I thought I would share.
Re: H22 guys..... Speedo is almost accurate if..... (fastwanabe)
Cool man, but how did you get those tires so quickly? I just got my new rims and tires yesterday, but still can't tell yet if my speedo is more accurate. Are the azeni's rubbing at all on your car?
Re: H22 guys..... Speedo is almost accurate if..... (junglerunna02)
the rear did rub till I rolled them in and the front rub if I hit a pot hole while I turned, the rub less than I thought they would.
Re: H22 guys..... Speedo is almost accurate if..... (hot_EH)
You should try racing at the track with a JDM cluster in a H22 Civic.... throws you way off (reads a lot higher than what you run). All motor, I'd be at 180 km on the speed and only pull 104-108 mph trap speeds. With NOS, I'd be well past 180 km (which is approx 112 mph) and I'd be hitting 112-117 mph trap speeds. Now that I think about it, the same also applied when I was B20 (B-series) and even when turbo B20... weird (damn JDM clusters )
Re: H22 guys..... Speedo is almost accurate if..... (Newman)
Also I noticed that the car is about 1" higher off the ground with the new tires, I still have the lowered look with some ground clearance.. Now I wont have to worry about smashing my header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">Also I noticed that the car is about 1" higher off the ground with the new tires, I still have the lowered look with some ground clearance.. Now I wont have to worry about smashing my header.</TD></TR></TABLE>
haha. you should get yourself some 18" rims with 235/60R18. You're speedo will be dead on
Jon is trying out the YellowBox. Hopefully that works.
Re: H22 guys..... Speedo is almost accurate if..... (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
Jon is trying out the YellowBox. Hopefully that works.</TD></TR></TABLE>
What is that?
What is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 »</TD></TR><TR><TD CLASS="quote">
What is that?</TD></TR></TABLE>
It's an ESS corrector. It's bad ***!
here's a link:
http://www.blackrobotics.com/index.htm
here's a link:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 »</TD></TR><TR><TD CLASS="quote">That is bad *** Id like to know how that works out for him.</TD></TR></TABLE>
Yep. I hope it works well.
Re: H22 guys..... Speedo is almost accurate if..... (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD »</TD></TR><TR><TD CLASS="quote">Nice how was your rt's with the new tires..? And did you times improve any at all?</TD></TR></TABLE>
unfortunetly it didnt help me drop my times, however my 60' went from 2.2 down to a 2.1 but I still ended up with a low 14 1/4 time. I was only able to get one run but I be back at the track wed and try it again.
zboog929
12-06-2008 07:19 PM
zc911
03-13-2007 05:52 PM
