ls/vtec headstuds
Old Jun 5, 2003 | 11:40 AM
Chuji's Avatar
Default ls/vtec headstuds
Yes I did a search and I could'nt find anything so my question is... I'm using an ls block w/ a b16 head which headstuds do I use. Some say the GS-R headstuds are a little too long and cause the headgasket not to seal right. Are the b16 headstuds the way to go or what?
Old Jun 5, 2003 | 11:55 AM
torr's Avatar
Default Re: ls/vtec headstuds (Chuji)
ls-to long
b16- to short
gsr- the way to go
Old Jun 5, 2003 | 01:08 PM
Jeff C's Avatar
I am using ARP GSR headstuds on my crvtec w/o probs.
Old Jun 5, 2003 | 05:18 PM
IWearMyKswiss's Avatar
New User
you should use b16 headstuds,...and if you are gonna be looking at anything over 200 horsepower i would recommend getting ARP headstuds
Old Jun 5, 2003 | 05:35 PM
ChaseIntegra's Avatar
Default Re: (WiDeBoDyEK)
Ok one person says B16 head studs are too short and someone else says they are the ones to use. We need someone to answer this question who knows which ones to use or someone that is doing the same swap. I know one says GSR's are fine. sooooooooooo...
Old Jun 5, 2003 | 05:46 PM
New User
Default Re: (ChaseIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Ok one person says B16 head studs are too short and someone else says they are the ones to use. We need someone to answer this question who knows which ones to use or someone that is doing the same swap. I know one says GSR's are fine. sooooooooooo...</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=524826 i dont know if this will help or not
Old Jun 5, 2003 | 11:09 PM
MPower332TI's Avatar
I would use the ARP studs that correspond with the head. B16=B16 studs, GSR=GSR studs. Also all the bolts are the same on the ls and the GSR except for the 2 center ones.
Old Jun 6, 2003 | 09:22 AM
DOHCarp's Avatar
Default Re: (jDmDxTuRd)
From my personal experiance I just finished an LS/vtec with a B18B botom end and a B16 head. I searched for B16 ARP head studs but everyone was on back order so I opted for the B18C1 ARP head studs.
Everything went together great with about a 1,000 miles on it so far.
Old Jun 6, 2003 | 07:31 PM
NA EJ1's Avatar
Default Re: (DOHCarp)
ARP=
dtenakoun
Feb 19, 2009 10:23 PM
da9stalker
Aug 4, 2008 05:51 PM
1crazysir
Oct 1, 2006 07:36 AM
EGJDM
Jun 27, 2004 07:55 AM
Boost2NA
Jul 10, 2002 09:24 AM
