problems finishing wiring up harness?
i am doing a b16a swap into a 91 crx si. i am using the stock harness of the previous motor that was in there plus a subharness i purchaced from hasport. i have a dc header and it came with a harness also. all i really need to know is if anyone else has done this same setup and if you have to cut any of the wires out or do any modifications to have everything plug in properly. the main part i need to know is the o2sensor, if there is any modification to have that plug in properly. thanks
Modified by rexheadb16a at 5:06 PM 5/31/2003
Modified by rexheadb16a at 5:10 PM 5/31/2003
markdman
09-22-2003 09:34 AM
