CRITICAL HELP: Engine Harness related question.
I have a 1997 Civic DX, with a B18C5 motor and 97 itr P73 ecu.
Will the 1997 Del Sol B series engine harness plug right in without any modification?
Reason for asking is because I am having problems with my existing modified DX engine harness.
Thanks
Re: CRITICAL HELP: Engine Harness related question. (oem)
damn, that should be close - might have to check the back of the block and see if you have the temp sensor on the civic motor, cause the itr does not...
ps that is the sensor with the tow prongs sticking out of what looks like a green gel base
Yes it will work. Unless you purchase the 97 del Sol VTEC harness from the dealer, that harness will be a pain in the *** to find.
Unless you already have one.
But the B18C5 and the B16A2 that comes into the del Sol VTEC are the same.
Instant Message blown90hatch. he is a harness guru....also, I have a 99 GSR engine harness for sale.. If you are interested let me know
stiffinEK
11-22-2009 04:49 AM
oem
06-10-2003 03:28 PM
