D16Z6 Help!!!
Old Jun 23, 2003 | 04:52 AM
danielcrx's Avatar
Default D16Z6 Help!!!
I just put a D16Z6 into my 89 crx hf. I am trying to use the P28 ECU and convert to OBD1 so I can run the V-Tec from the ECU. The wiring is a bloody mess. Any help with wiring advice, or parts that I need would be great! Thanks.
Daniel
Old Jun 23, 2003 | 05:43 AM
UpstateCivic's Avatar
Default Re: D16Z6 Help!!! (danielcrx)
Blown90Hatch did a GB on OBD0-1 conversion harnesses. We just did the same swap and it made it so much easier. Otherwise you're looking at hardwiring everything. Also, talk to Katman at JHP, he can prolly help you.
Old Jun 23, 2003 | 08:12 AM
danielcrx's Avatar
Default Re: D16Z6 Help!!! (UpstateCivic)
How difficult would it be just to bolt up an Si intake manifold, engine harness, and ecu. I've already butchered the z6 engine harness, and my Hf engine harness, to try and hard wire the connections. I'm not sure I'm capable of making this work, even though I already have the mechanical part of the swap done. I can't find enough information to go wire to wire for the p28 ECU I have.
Daniel
Old Jun 23, 2003 | 11:31 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielcrx &raquo;</TD></TR><TR><TD CLASS="quote">I just put a D16Z6 into my 89 crx hf. I am trying to use the P28 ECU and convert to OBD1 so I can run the V-Tec from the ECU. The wiring is a bloody mess. Any help with wiring advice, or parts that I need would be great! Thanks.
Daniel</TD></TR></TABLE>
well, i hate wiring, so I personally try to find the easier route to go with. I'll suggest this to you...
Stick with your orginal HF wiring, ignition, and fuel injectors....then find yourself an 89-91 B16A PR3 ecu + have it reprogrammed w/disabled sensors (KS, 2nd 02, and VTPS) and all you'll have to do is wire up 1 single wire.....which is the vtec solenoid and presto....your vtec will work.
(hit me up if you decide to go this cheaper route. I reprogram ecu's)
Old Jun 24, 2003 | 08:53 AM
danielcrx's Avatar
Default Re: D16Z6 Help!!! (Katman)
I will trade my P28 to anyone out there with a PR3. Katman, how much to reprogram?
Thanks,
Daniel
Old Jun 26, 2003 | 05:18 AM
danielcrx's Avatar
I got a deal locally on a b18a1 computer, an si intake, and an si ingine wiring harness for 150, in trade for my p28. Should that work if I wire up the vtec to a switch? And, is that a good deal?
Thanks,
Daniel
Old Jun 26, 2003 | 09:40 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielcrx &raquo;</TD></TR><TR><TD CLASS="quote">I got a deal locally on a b18a1 computer, an si intake, and an si ingine wiring harness for 150, in trade for my p28. Should that work if I wire up the vtec to a switch? And, is that a good deal?
Thanks,
NO NO NO!!!! get your P28 BACK!
Do you really need those parts? and btw, the B18A1 ecu is NOT able to be converted to VTEC! it has to be a PR3 ecu!
Alex_S
Jul 27, 2014 03:20 PM
d16z6crx88
Jun 23, 2008 07:49 AM
memorybox
Jul 4, 2006 10:06 AM
Amf_crx
Mar 20, 2004 02:52 PM
Brownjd
Oct 15, 2003 02:09 PM
