code 9 #1 cylinder position sensor-just did swap!!
car 93 civic cx
motor d16y8
ecu p28
swap is in and everythng wired up. the car fires up but idles like a race car or a car with a race cam in it. with the p28 it threw 0, 4, 9, 29.. so i think my ecu is phucked. so i pluged in my cx p05 ecu for comparison and it only throws code 9-no other codes!
i think that when i rewired the obd2 dizzy for obd1 i switched one or two wires?? could this be?? does anyone have a dizzy diagram?? i am in the dark here and i appreciate any help. thanks
motor d16y8
ecu p28
Re: code 9 #1 cylinder position sensor-just did swap!! (mycvc8u2)
Swap the locations of the ORG and WHT wires on the distributor... either that or swap the wires at B11 & B12. Those are your CYP wires.
Re: code 9 #1 cylinder position sensor-just did swap!! (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">Swap the locations of the ORG and WHT wires on the distributor... either that or swap the wires at B11 & B12. Those are your CYP wires.</TD></TR></TABLE>
thankd-will check later. anyone else?? morning bump
well i just realized there are 2 org wires and 2 wht wires0would you happen to have a dizzy diagram?? in your opinion would this make the car idle all over the place?? and fall onit's face when i hit the gas a bit?? thanks again
drinks2k
05-10-2007 10:15 PM
mycvc8u2
06-28-2003 06:24 AM
