ROD KNOCKing AFTER swap
okay. i just dropped a b16a in my 91 teg. it ran fine at first but throwing a code 22 due to a wiring problem. with that fixed and no codes present i drove to see if vtec would crossover. it didnt. so i checked oil again. its full. now i can hear a slight knock when i first start the car. it seems like after the motor gets oil pressure it kinda drops off and goes silent. but when i would rev just a little (like to 2500-3000rpm) i could hear a knock from the bottom-end. i am saying its a rod knock. it seems very slight at the moment and i am not going to drive it anymore.
1) how much damage do you think has been caused?
2) could i just put new bearings in it and if doesnt knock or seize up i am good right?
3) do you think i will need the crank reground?
any opinions greatly appreciated.
Re: ROD KNOCKing AFTER swap (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">
1) how much damage do you think has been caused?</TD></TR></TABLE>
IF the damage is not the bad, you will have to regrind crank and get oversized bearings. I would personaly find a used B16 or B18c and slap it on. (that will prolly be your cheapest way out)
2) could i just put new bearings in it and if doesnt knock or seize up i am good right?</TD></TR></TABLE>
The chances of that are slim. You will at least have to regrind the crank and buy oversized bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">3) do you think i will need the crank reground?</TD></TR></TABLE>
Yes, read what I said before.
Hope that helps!
Hope that helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">what would a b18c crank do? stroke the motor?</TD></TR></TABLE>
Yeah, but you have to machine it in. I would just get the whole bottom end.
Re: ROD KNOCKing AFTER swap (turbogixxer)
na. i am just probably getting crank redone, new bearing and labor. its 350 just to do bearings ill probably have $500-550 wrapped up in all that and it isnt even a complete rebuild!!
Re: ROD KNOCKing AFTER swap (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">Do you still have a good bottom end from the B18A that came from your car? Why not use that and build an LSVTEC?</TD></TR></TABLE>
i do but it has alot of miles on it. 196k. it would be cheaper just to re-bearing the b16 even if i have to pull the crank and get it reground.
