Shielded wire for 02? Is this a must?
Old Jun 29, 2003 | 12:18 PM
Jonathan_ED3's Avatar
Default Shielded wire for 02? Is this a must?
I'm redoing ALL of my o2 wiring since I can't keep from throwing a code, and I was wondering if the white wire has to be shielded? It's not shielded form the ecu to the strut tower harness, so I don't understand why it's shielded between the strut tower harness and the 02 plug.
Is shielded wire a must for it?
If so, is that something I can just buy at like Radio Shack or something? Trying to get this done today
TIA
Old Jun 29, 2003 | 12:53 PM
Newman's Avatar
New User
Default Re: Shielded wire for 02? Is this a must? (hot_EH)
On a 1-wire O2, it's not a must.... but on a 4-wire O2, it's recommended so there's no interferance or feedback from the other wires.
Old Jun 29, 2003 | 01:46 PM
Default Re: Shielded wire for 02? Is this a must? (Newman)
Thanks.
Do you know if it's something I can just buy at Radio Shack? Or will shielded audio wire work?
Old Jun 29, 2003 | 02:22 PM
Lei Siew Long's Avatar
i tried but, radio shack doesn't carry shielded wires. i had to go to a small mom's and pop's type electronics store to purchase the shielded wire.
Old Jun 30, 2003 | 07:34 AM
Default Re: Shielded wire for 02? Is this a must? (Hatch4urSnatch)
thanks for the tip, saves me a trip.
Does anybody know if I have to buy it as a unit, or if I can just by the 'sheath' and slide over an existing wire?
Old Jun 30, 2003 | 07:43 AM
Could I use an RCA patch and just cut off the plug? Then use the positive splice for the source, and use the negative splice as the shield?
Old Jun 30, 2003 | 08:49 AM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH &raquo;</TD></TR><TR><TD CLASS="quote">Could I use an RCA patch and just cut off the plug? Then use the positive splice for the source, and use the negative splice as the shield?
</TD></TR></TABLE>I wouldnt suggest doing that because the wire that carries the o2 signal is different than most other wires. RCA wires are mostly copper have have a higher resistance than the material the o2 wires are made of.
BTW... I do have a spare female side plug for the o2 if you need one. PM me.
Old Jun 30, 2003 | 10:21 AM
Default Re: Shielded wire for 02? Is this a must? (fastwanabe)
hmmm. well, do you know what kind of wire I should use?
I've really got no clue where to look/what exactly to get, but I don't want to risk throwing more codes by not having a shielded wire there.
Old Jun 30, 2003 | 02:23 PM
they sell it by the foot and the shielded wire came with two 18 gauge wires in one large gray shield. the shield is similar to the black shield on the television cable wires.
Old Jun 30, 2003 | 03:20 PM
they sell it by the foot where though?
Old Jun 30, 2003 | 05:35 PM
i bought it from a mom's and pop's type electronics store where they focus primarily on electronics parts such as diodes, resistors, parallel ports, solders, etc here in southern california.
Old Jun 30, 2003 | 06:34 PM
oh I'm sorry, I didn't pay close enough attention to realize you already told me that.
Old Jun 30, 2003 | 06:55 PM
it's cool
Rease3
10
Jun 24, 2009 05:08 PM
immorality
Sep 30, 2008 10:09 AM
sherman
Mar 17, 2003 06:04 PM
nsxmatt
Aug 7, 2002 07:20 PM
