H22 Ek wiring??
Re: H22 Ek wiring?? (st0nedstoopid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st0nedstoopid »</TD></TR><TR><TD CLASS="quote">Anyone have any sites on the wiring info for wiring h22 in EK.. how hard is it to do</TD></TR></TABLE>
Umm I just did that swap. 94 JDM h22 into a 99 civic.
Re: H22 Ek wiring?? (junglerunna02)
If using the EK engine harness, jdm obd1 ecu and motor, all that needs to be done would be to splice and match up the wires for dist., alt., inj., and starter? its not plug n' play is it?
thanks
thanks
Re: H22 Ek wiring?? (breakaway)
Well depends which wiring harness. I used the my stock DX harness and had to add quite a few things. Heres a wiring diagram curtiousy of Poison, hopefully he wont mind to much.
Re: H22 Ek wiring?? (poison)
Iam using The OBD2 to ob1 wiring harness iam just soo f-ing confused on all the differnt sh it iam hearing about wiring .. now i have stock CX wires .. i have the cut Prelude wiring harness that came with ECU and then i have the OBD2 to OBD1 wiring harness .. anyone can maybe tell me what ineed to straigten this up
well, i have a '98 ek cx and am having the same problems as he is...i'm using the cx engine harness and the obd1 p13...do i just cut and match the wires from the prelude (dist., alt., inj., starter) onto the civic harness? and add the wires for the extra stuff on the h22 that the civic didn't have? or is their an easier way i'm not seeing..?
thanks for any insight
