Why cant you use 90-93 axles in 94+ Integra's ???
Re: Why cant you use 90-93 axles in 94+ Integra's ??? (poison)
Well damn ...I have lifetime warrent axles at autozone but they are for 90-93 and I need a new one . Thanks man you alkways answer my replys in here : p
Re: Why cant you use 90-93 axles in 94+ Integra's ??? (BALL BAG)
if that 's the case.. are the 90-93 knucles interchangeble w/ 92+ civics?? or will there be axle length issues?
Re: Why cant you use 90-93 axles in 94+ Integra's ??? (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB »</TD></TR><TR><TD CLASS="quote">if that 's the case.. are the 90-93 knucles interchangeble w/ 92+ civics?? or will there be axle length issues?</TD></TR></TABLE>
Yep, 32mm hub. The outer CV joint and the inner CV joint should be interchangable. But the axle shaft is about 2" shorter compared from 90-93 integra axles to 94+.
It also depends which motor is inside the car as well. Being a B series in a 92+ Civic or 94+ Integra, it'll be 94+ B series axles.
For EF (88-91) and DA (90-93) Civic/Integras, it'll be 90-93 B series axles with a B series engine.
For H/F series, that is a whole different story.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALL BAG »</TD></TR><TR><TD CLASS="quote">Any clever ways to get Autozone to give me a 94 axle instead of 90-93 </TD></TR></TABLE>
Of course, tell 'em it doesn't fit and those bastards gave you the wrong part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALL BAG »</TD></TR><TR><TD CLASS="quote">lol Ok ill try </TD></TR></TABLE>
Do it with a little attitude, and it'll work.
EF9-CIVIC
12
05-17-2007 05:57 PM
